two sessions with same dot1x cerdenitial in the same time , is that valid ?
  • 1.  two sessions with same dot1x cerdenitial in the same time , is that valid ?
    Posted Jul 03, 2016 05:45 AM
  • 2.  RE: two sessions with same dot1x cerdenitial in the same time , is that valid ?
    Posted Jul 03, 2016 06:38 AM
    Do both sessions have the same ip address?
    Is this a mobile device?
  • 3.  RE: two sessions with same dot1x cerdenitial in the same time , is that valid ?
    Posted Jul 03, 2016 06:43 AM
    the case is i configured new profile with dot1x authentication , the authentication is from local DB , and the username is : admin and password is admin123 .
    i connected my pc to the ssid with above credentials , while I'am connected  my college tried to connect with same credentials , the authentication success but he didn't get ip address , he got apipa IP !
  • 4.  RE: two sessions with same dot1x cerdenitial in the same time , is that valid ?
    Posted Jul 03, 2016 06:48 AM
    Two different devices can have the same credentials, yes.  If you had a phone and a laptop and they used the same credentials, it is valid.  Your devices should get two different ip addresses.
    What is supplying DHCP?
  • 5.  RE: two sessions with same dot1x cerdenitial in the same time , is that valid ?
    Posted Jul 03, 2016 06:49 AM
    its windows server 2008
  • 6.  RE: two sessions with same dot1x cerdenitial in the same time , is that valid ?
    Posted Jul 03, 2016 07:00 AM
    I found the dhcp Pool have no free IPs ,,, thank you :)
