Contributor I
unable to restore running configuration
Hi Forum,
I want to restore only running configuration to replace existing configuration. I successfully transferred Running Config. file from TFTP to Flash file system now how can i replace my current running config with my transferred running configuration file, all other configuration must be remains same.
Faisal
Re: unable to restore running configuration
Under Maintenence> Controller > Boot Parameters, you can select which file is selected after the reboot.
