Frequent Contributor II
understanding port channel
Hi there,
I configured LACP in one controller but having issue to understand the behaviour of it.
My port channel is configured as trunk but  when i'm running "sh run" its showing " switch port access vlan 9" under "switchport mode trunk".
below the configs ..
interface port-channel 1
        trusted
        trusted vlan 1-4094
        switchport access vlan 8
        switchport trunk allowed vlan 1094
rana
Re: understanding port channel
The port channel configuration supersedes the interface configuration if the interface is part f the port channel. It looks like that port channel does not have any interfaces added...
EDIT:
Whatever is at the end of the "switchport mode" command determines if it is a trunk or an access port.  In your case, it is a trunk
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Two interface are assigned to taht port channel ...
interface gigabitethernet 0/0/0
        description "GE0/0/0"
        trusted
        trusted vlan 1-4094
        lacp group 1 mode active
interface gigabitethernet 0/0/1
        description "GE0/0/1"
        trusted
        trusted vlan 1-4094
rana
I corrected my post.  Please see above.
Thanks Colin,
But why its coming there ,
There are other vlan also buts why only vlan 8.
rana
1.  The port channel configuration supersedes the interface configuration when the interface is part of that lacp group
2.  If the port channel configuration has a "switchport mode trunk" command, all "switchport access"
commands are ignored.  Only "switchport trunk" commands are applied.  That makes it easy to switch between switchport mode trunk and switchport mode access and have your access and trunk configuration easily applied.
I hope that makes sense.
Trunk configuration will override access port configuration. If it was switchport mode access, that line would be active.
Sent from Nine
Tim Cappalli | Aruba Security
