Regular Contributor I
usb modem params for RAP3wn Huawei e353
Hi community,
one of our customer wants to get his Rap3 works with 3g uplink.
He bought a Huawei e353 stick, whitch is on the list of supported devices.
When he put the stick in the Rap it does not work.
Have anybody the right params for the Huawei e353?
Modeswitch ... ?
Re: usb modem params for RAP3wn Huawei e353
Hi Leon,
We have tested Huawei E353 with Chinese provider Unicorn where it had worked as expected.
Also that we had tested RAP5 in 6.1.2.3 with the below provisioning parameters,
usb_type=2(option)
usb_dev=0x12d11506
usb_modeswitch="-v 12d1 -p 1446 -M 55534243123456780000000000000011062000000100000000000000000000"
usb_dial=ATDT<Dialer>,
usb_init=AT+CGDCONT=1,'IP','<APN>'
If we give in the correct parameters (Dial String, Initialization String, etc.,) after collecting it from your server provider then it should work fine.
Thanks.
