users not acquiring the correct ip address for 1ssid with 3 roles
Hi! I configured a ssid with 4 roles, 1st role is for clearpass captive portal, 2nd to 4th role are the roles after the initial role but when the approver accepts and place the user to its role the ip address of the user is not changing to its specified vlan subnet.
Re: users not acquiring the correct ip address for 1ssid with 3 roles
Please see this:  http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Can-I-return-a-different-user-Vlan-after-L3-Captive-portal-based/ta-p/245813
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
So it will not change to a different VLAN anymore?
