visual RF issues
Has anyone else has issues with this?
for example suddenly its not working and there is nothing i can do to make the coverage signal to work... it just show me all in red or all in light blue...
I see you guys dont update it since 2016
Is there any reason for that? or there is another tool? or we have to buy ekahau for this?
Cheers
Carlos
Alternetworks Corp
Regular Contributor II
Re: visual RF issues
Hi Carlos
On which version? The standalone version or the one build into AirWave?
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
yeah stand alone version
Cheers
Carlos
Alternetworks Corp
Hi Carlos,
That version is old. Maybe an issue after update on Windows? Or Java?
I only used this version a few times to test. All customers run the AirWave version.
Cheers, Frank
