vlan mobility and mobile ip
what is diffrent betweent vlan mobility and mobile ip?How do they work?
Re: vlan mobility and mobile ip
Vlan mobility = Layer 2 mobility
Mobile ip = Layer 3 mobility
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-does-VLAN-mobility-work/ta-p/179040
http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_UG/Mobility.php
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you relpy!
When enable L2 roaming, the client roams from one controller to another, requiring both controllers to have the same user VLAN,right?
Another question, does L3 mobility require two controllers in the same master-local?
Yes
Get Outlook for iOS
Thank you
Victor Fabian
Just confirm again, L3 mobility requiring both controllers in the same master-local?
Assuming a scenario, two Local controllers belong to different Master-local relationships. Can clients implement Layer 3 mobility between the two Local controllers?
