voice ssid
I am using one sip client (mobile ) in our wlan and a separate voice ssid created for  cisco wireless phones. So what is the qos recommendation
Thank you
Re: voice ssid
I would match the WMM/DSCP marking on the SSID profile to your wired DSCP values.   For most wired VoIP configurations, voice will be marked as 46.
--Kevin
