Contributor II
vrrp security problem
hi all
    anybody consider the vrrp authentication string cleartext issue? anybody can capture the string and do something easyly, just they are in management vlan.
   so unless redudancy MCs and AP is not same vlan.
    if vrrp authentication string can be encrypted, I think that will be better.
regards
Kevin
Trusted Contributor I
Re: vrrp security problem
i don't believe it is really meant as a security feature.
