vrrp using gui
  • 1.  vrrp using gui
    Posted Mar 18, 2014 07:29 AM
    I am having 3600 controller with 6.3.1.3 os version . I would like some one to sahre the gui based setps to setup vrrp settings
    regards
    #3600
  • 2.  RE: vrrp using gui
    Posted Mar 18, 2014 07:32 AM
    VRRP can be found under Configuration > Advanced Services > Redundancy:
  • 3.  RE: vrrp using gui
    Posted Mar 18, 2014 07:44 AM
    Hi Tim,
    Thanks for your response.
    can I have the screen configuration shot steps for both the master and backup controller respectivly.
    regards
  • 4.  RE: vrrp using gui
    Posted Mar 18, 2014 08:09 AM
    jayakumar,
    Both controllers will be identical except the peer address will be the other controller.
    For example:
    Master IP = 10.1.1.2
    Backup IP = 10.1.1.3
    so,
    VRRP IP = 10.1.1.1
    Master Peer IP = 10.1.1.3
    Backup Peer IP = 10.1.1.2
  • 5.  RE: vrrp using gui
    Posted Mar 18, 2014 08:56 AM
    The Campus VRD has the screenshots you are looking for.  They are in this section:  http://www.arubanetworks.com/vrd/CampusWNetworksVRD/Chap5_Redundancy.html#1030870.  It covers both sides of VRRP both CLI and WebUI.
    Example from the VRD:
    Primary:
    Primary
    Backup:
    Backup
