what does unapplied changes to a group mean?
  • 1.  what does unapplied changes to a group mean?
    Posted Jan 30, 2014 03:17 PM
    what does 'unapplied changes' mean? how can you check to see what those changes are before they are applied?
    Kevin
  • 2.  RE: what does unapplied changes to a group mean?
    Posted Jan 30, 2014 04:55 PM
    If this is regarding AirWave... then:
    This means that someone with admin access to that group made a change and saved, but did not apply the change.  There's not an easy way to view without touching the database directly, this seems like a good place for a feature enhancement.  In the interim, if you take a screen shot, then revert, you'll be able to eyeball the difference.
