Frequent Contributor II
what is the best scenario to configure 4 controller in the same building ?
I need to know   what is the best scenario to configire 4 controllers and they have the full license capacity for 400 access points what is the best scnario and how to do it?
Re: what is the best scenario to configure 4 controller in the same building ?
May I model of controller and access points ?  We may also need to understand what type of clients/application/Business cricality/application used on network/APtype of deployment so that we could better design/plan to impement WLAN.
2 controller 6000 series and 2 3600 ,can I terminate a specifeic access points on each controller for example 100 access point on each one?
Yes absolutely you can load balance the access points between controller as long as AP can talk to controller and find the master.
You can configure LMS IP and Bkp-LMS ip from AP system profile on the controller ap-group.
LMS-IP -- this would be primary ip address of the master controller where AP would try to talk to and terminate GRE traffic
Bkp-LMS IP -- this would be secondary basically fail over mode when primary is not reachable or in failure.
Sriram
