what is the most speed supported by the aruba APs for a DSL or ADSL%3F
Hi
I just want to know what is the most speed supported by the Aruba AP or Roters for an ISP ADSL or DSL link
Any kind of help or documentation will be greatly recibed
thanks in advanced
Aruba
Re: what is the most speed supported by the aruba APs for a DSL or ADSL%3F
Are you talking about RAP devices?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
