what means system log
hello
my controller is AOS-W (MODEL: OAW-4306G), Version 6.3.1.4
i checking system log and i found this log
May 16 18:30:29  KERNEL(1.1.12@x.x.x.x): ath_reset: unable to reset hardware; hal status 14
what means this log
please help me....
thank you
Re: what means system log
We would need to see the full log to understand the impact.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
The contents of the system log are the same.
What command should I enter to view the required logs?
i don't know what can i do.
thank you for reply me
