Contributor II
where is Plan tab on Aruba controller web UI
dear All
       I want to generate the CGI file import then be imported into VisualRF,but I cannot find the Plan tab,rhe  ArubaOS version is 6.4.3.5, anyone could tell me, very thanks.
Re: where is Plan tab on Aruba controller web UI
6.2 was the last version of AOS with RF Plan. You can use it in AirWave.
Sent from Nine<>
Tim Cappalli | Aruba Security
Contributor II
dear Tim
        very thanks。
