Frequent Contributor II
whitelist approved entries
Is there a way to keep new entries in the Control Plane Security Whitelist in the Approved status? When I add new APs into the list as approved, they stay that way for a period of time but then automatically flip to not approved.
I used the following syntax currently:
whitelist-db cpsec modify mac-address aa:bb:cc:dd:ee:ff state approved-ready-for-cert
I swear they used to stay approved with that command, seems later versions of code may have changed this behavior.
Re: whitelist approved entries
I will answer my own question :-)
Instead of approved, I put them into Certified state. They keep this and dont revert.
