Occasional Contributor I
why ip-tel is funcioning with tunnel and not in split-tunnel when ap105 is configured as RAP?
I have an alcatel ip-tel which i want to use in 2 different situations: Situation 1 works, situation 2 doesn't work.
Situation 1
ap105 is configured as RAP  (controller controle plane security disabled)
vap is confiuged as Tunnel  -> vlan 140
ip-tel works normal and is connected
Situation 2
ap 105 is configured as RAP (controller control plane security disabled)
vap is configured as Split-tunnel -> vlan 140
ip-tel is in role with policy:   any any any permit    (so everything goes through the tunnel)
ip-tel doesn't work and stays in "connecting" status
Can somebody explain me this? for my part of view, everything goes throught the tunnel and there should
be no difference between the 2 situations.
Peter D'affnay
MVP
Re: why ip-tel is funcioning with tunnel and not in split-tunnel when ap105 is configured as RAP?
[ Edited ]
if all the traffic should go to the Controller then use tunnel mode... there is no use of that rap in split tunnel if you doing thtat...
Please put it on tunnel mode and try again.
Split tunneling is not made to do that.
Cheers
Carlos
Alternetworks Corp
Hello Carlos,
thanks for your reply!
This was just a test.
I have a custumor whith a lot off locations using RAP.
This custumor has also a lot off caps.
He has a centralised call-server.
The ip-phones connecting to the CAP's are all working fine.
All the ip-phones using the RAP's are not working. (always stay in connecting mode)
-> here all the trafic should be localy bridged.
So, i was thinking that the firewall inside the rap is blocking some traffic.
So i started with configuring the rap in split-tunnel mode and tunnel all the traffic to the controller.
Even then.... the ip-tel doesn't come up....!!!!
I don't know what traffic is blocked inside the rap.
In attachement i will give a snifferfile of the working telephone when the telephone is in tunneled mode.
Is it possible the RAP is blocking NOE protocol?
greets
Peter D'affnay
The snifferfiel in attachement
Peter D'affnay
MVP
[ Edited ]
Question
So you got it bridged okay thats fine...
Do you have a private link between both 2 sites?
Is the network where the ip phone belongs onthe remote site can reaach the alcatel pbx???
Did you put on the alcatel ip phone the tftp server  the ip of the pbx all that on the phone? statically? or you are dynamically sending that data? because if you are then you need to set properly the things on the DHCP server?
How is your PBX set up?  is he the DHCP server or what? or you putting statacally all the values on the Ip phones
Need more info :)
 I dont think they are blocking anything unless you specify it to do it on the control access.
Alternetworks Corp
