rzz
Contributor II
wips and auth
whats the difference between wips on instand and lic rfp?
and for authenicatiom servers, if a list is configured, will it exhaust the whole list before rejecting for instant based?
Re: wips and auth
Wips on instant and RFP license on the controller are comparable.
For authentication servers on instant, it will only try a second server if the first server does not answer.
Colin Joseph
Aruba Customer Engineering
rzz
Contributor II
Re: wips and auth
thanks joesph
rzz
Contributor II
Re: wips and auth
if they require a third or forth source, a mc/ cp will be required?
Re: wips and auth
No, you can configure two or more radius servers:  http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/Authentication/ConfiguringExternal RADIUS Server.htm
If you want all servers to be tried, you would need ClearPass or a Mobility Controller, BUT that is only useful if you have two entirely different databases that you would want to authenticate users in.  That would be useful if you are merging companies and you want to try company#1's AD and then company#2's AD in auth.  It is not useful if both servers are pointing to the same AD.  You can just use instant and the second or third server will be tried, if the first or second server does not answer.
Colin Joseph
