wireless timers?
Is there a timer I can set on aps , we are hoping to tun off wifi at our off site locations during off hours. Can this be done?
#AirheadsMobile
Re: wireless timers?
Are these instant or controller-based APS?
controller based
#AirheadsMobile
The deny time range feature in the virtual ap profile can do this. http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/wlan_virtual_ap.htm?Highlight=Virtual-ap
It will not turn off the wifi, but it will deny connections at that time range specified.
