Frequent Contributor II
wireless users redirected to controller login
I have a customer that has wireless users being redirected to the master login screen when trying to go to their domain homepage. Is this a role issue? Unfortunetly, I dont have access to check their config....
Re: wireless users redirected to controller login
Is the controller set to use 443 for management?
Tim Cappalli | Aruba Security
I'll ask...
It is not set to 443.
Super Contributor I
Can you grab a snippet of the rules in that role?
ACDX #419 | ACMP |
Aruba
Two things to check:
  1. what IP is provided by DNS lookups for their domain homepage (from a client that is having the issue)
  2. what is the output of show rights <Name-of-Role>
AMFX | ACCX | ACDX | ACMX
FYI, Here is what TAC found:
Latest Status changed to:
1. Had conversation with customer regarding the issue.
2. We verified the logs & found that we had custom cert mapped under server certificate option.
3. Common Name on the certificate was set to companydomain.com
Hence, the wireless users were being redirected to this controller's Web GUI.
4. We changed the server certificate mapping under Web-server to default post which the users were redirected to the actual website.
