Trusted Contributor I
wlsx(N)UserAuthenticationFailed not being send
working with airwave and the controller, configured SNMP traps and seeing traps come in, but when an authentication fails i dont get the wlsx(N)UserAuthenticationFailed traps. anyone got a clue on the reason?
they are enabled
(name) #show snmp trap-list
SNMP TRAP LIST
TRAP-NAME                                  CONFIGURABLE  ENABLE-STATE
authenticationFailure                      Yes           Enabled
wlsxMgmtUserAuthenticationFailed           Yes           Enabled
wlsxNUserAuthenticationFailed              Yes           Enabled
wlsxUserAuthenticationFailed               Yes           Enabled
Re: wlsx(N)UserAuthenticationFailed not being send
ok, think i found it, disabled EAP termination and the traps were send.
could that be it? anyone got a clue why they aren't send with EAP termination enabled?
That trap is only sent for an authentication failure from an authentication source.  If your problem existed between the client and the controller, your problem might be with certificate or EAP setup vs an actual authentication failure.  I would turn on client debugging and see what the auth-tracebuf says.
Please let us know if you enter a wrong username and password and see if it sends the trap.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
ok, did the testing, this what i get with a wrong request and EAP termination on
Jun  8 23:45:41  station-down           *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -
Jun  8 23:45:42  station-up             *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -    wpa2 aes
Jun  8 23:45:42  station-term-start     *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     31  -
Jun  8 23:45:42  eap-term-start        ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -
Jun  8 23:45:48  station-down           *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -
Jun  8 23:45:49  station-up             *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -    wpa2 aes
Jun  8 23:45:49  station-term-start     *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     31  -
Jun  8 23:45:49  eap-term-start        ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -
Jun  8 23:45:56  client-finish         ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -
Jun  8 23:45:56  server-finish         <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   61
Jun  8 23:45:56  server-finish-ack     ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -
Jun  8 23:45:56  inner-eap-id-req      <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   35
Jun  8 23:45:56  inner-eap-id-resp     ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -    wrong
Jun  8 23:45:56  eap-mschap-chlg       <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   67
Jun  8 23:45:56  eap-mschap-response   ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  9   49
Jun  8 23:45:56  mschap-request        ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  9   -    wrong
Jun  8 23:45:56  mschap-response       <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/radius01            -   -    wrong
Jun  8 23:45:56  eap-mschap-chlg-retry <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   115
Jun  8 23:46:01  eap-mschap-chlg-retry <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   115
Jun  8 23:46:06  eap-mschap-chlg-retry <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   115
Jun  8 23:46:11  eap-mschap-chlg-retry <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   115
Jun  8 23:46:16  eap-mschap-chlg-retry <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   115
Jun  8 23:46:21  eap-mschap-chlg-retry <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   115
Jun  8 23:46:26  eap-failure           <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   4
and this for a succesful one
Jun  8 23:46:52  station-down           *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -
Jun  8 23:46:55  station-up             *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -    wpa2 aes
Jun  8 23:46:55  station-term-start     *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     31  -
Jun  8 23:46:55  eap-term-start        ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -
Jun  8 23:47:03  client-finish         ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -
Jun  8 23:47:03  server-finish         <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   61
Jun  8 23:47:03  server-finish-ack     ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -
Jun  8 23:47:03  inner-eap-id-req      <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   35
Jun  8 23:47:03  inner-eap-id-resp     ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -    test
Jun  8 23:47:03  eap-mschap-chlg       <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   67
Jun  8 23:47:03  eap-mschap-response   ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  9   49
Jun  8 23:47:03  mschap-request        ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  9   -    test
Jun  8 23:47:03  mschap-response       <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/radius01            -   -    test
Jun  8 23:47:03  eap-mschap-success    <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   83
Jun  8 23:47:03  eap-mschap-success-ack->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   -
Jun  8 23:47:03  eap-tlv-rslt-success  <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   43
Jun  8 23:47:03  eap-tlv-rslt-success  ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   2
Jun  8 23:47:03  eap-success           <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/p3t3-aaa-auth_prof  -   4
Jun  8 23:47:03  wpa2-key1             <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   117
Jun  8 23:47:03  wpa2-key2             ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   117
Jun  8 23:47:03  wpa2-key3             <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   151
Jun  8 23:47:03  wpa2-key4             ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   95
then with EAP termination off and a wrong one (same wrong one as with eap termination on)
Jun  8 23:49:03  station-up             *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -    wpa2 aes
Jun  8 23:49:03  eap-id-req            <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     1   5
Jun  8 23:49:03  eap-start             ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -
Jun  8 23:49:08  eap-id-resp           ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     1   10   wrong
Jun  8 23:49:08  rad-req               ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     74  198
Jun  8 23:49:08  rad-reject            <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/radius01            74  44
Jun  8 23:49:08  eap-failure           <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     1   4    server rejected
this with a good authentication and eap termination off
Jun  8 23:49:08  station-down           *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -
Jun  8 23:49:10  station-up             *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -    wpa2 aes
Jun  8 23:49:10  eap-id-req            <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     1   5
Jun  8 23:49:10  eap-start             ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -
Jun  8 23:49:15  eap-id-req            <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     1   5
Jun  8 23:49:20  eap-id-req            <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     2   5
Jun  8 23:49:25  eap-id-req            <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     2   5
and with a correct one
Jun  8 23:50:18  station-down           *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -
Jun  8 23:52:20  station-up             *  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -     wpa2 aes
Jun  8 23:52:20  eap-id-req            <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     1   5
Jun  8 23:52:20  eap-start             ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   -
Jun  8 23:52:25  eap-id-resp           ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     1   9     test
Jun  8 23:52:25  rad-req               ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     76  196
Jun  8 23:52:25  rad-resp              <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/radius01            76  90
Jun  8 23:52:25  eap-req               <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     2   6
Jun  8 23:52:25  eap-resp              ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     2   109
Jun  8 23:52:25  rad-req               ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/radius01            77  334
Jun  8 23:52:25  rad-resp              <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/radius01            77  1188
Jun  8 23:52:25  rad-accept            <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9/radius01            86  330
Jun  8 23:52:25  eap-success           <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     12  4
Jun  8 23:52:25  wpa2-key1             <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   117
Jun  8 23:52:25  wpa2-key2             ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   117
Jun  8 23:52:25  wpa2-key3             <-  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   151
Jun  8 23:52:25  wpa2-key4             ->  d8:50:e6:f3:70:1d  00:24:6c:32:b3:b9                     -   95
it seems that with termination the the reject doesnt show so the trap doesnt trigger, is that on purpose or something configured on my side?
I do not know.
