zabbix
I am trying to monitor a cisco WLC 2500 and the connected AIRCAP-1552E-A-K9 device.
I am using zabbix 2.4 version and added "Template Cisco WLC Discovery". However I am only able to monitor Uptime and WLC free RAM.
Can someone help me out what modification I need to do monitor Client data, Ap data ,serial number etc..
Any suggestion highly appreciated.
Deepak
Re: zabbix
You may want to ask this on Cisco or Zabix forums.
Tim Cappalli | Aruba Security
Re: zabbix
Thanks Tim Cappalli for the suggestion. I will update it in zabbix or Cisco forum.
Deepak
