Occasional Contributor I
zebra QL320 printers do not work with AW-25 and IAP215 APs
After replacing most of the Symbol AP and POE hubs in the warehouse with IAP215's controlled through the AW-25, Zebra QL320 mobile wireless printers no longer connect.  Once they're brought in range of one of the old Symbol AP's, they connect and print.
We're using MAC authentication, but I added the MAC addresses from all of the 320's by clicking on the Users link on the Security tab.  Doesn't seem like an authentication issue, though.  Will this system work with devices that only use older 802.11a/b/g implementations?
Re: zebra QL320 printers do not work with AW-25 and IAP215 APs
See if the older system had 802.11d/h enabled.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Haven't found settings for 802.11d or h (it's a Symbol AP3141 & over ten
years old).
http://community.arubanetworks.com/t5/Controller-Based-WLANs/Why-Motorola-MC2180-bar-codes-is-unable-to-connect/ta-p/184458
Try only the 892.11d/h settings first.
Thanks, I'll give it a shot, test it, and let you know...
Enabled d/h, but it didn't help.
Any chance the problem is an authentication issue? I'd be willing to disable MAC authentication if it got them working, but I'd rather not if I didn't have to.
Also considering adding back a few of the old Symbol AP's to the network.  What kind of issues could doing that cause?
Trusted Contributor I
hard to predict, but why not just try, first an open SSID, then add WPA2, then ...
see where it fails or if it already fails directly
putting the symbols back will probably cause issue when a client jumps from them to an Aruba one.
also i would advise you to work with support on this, they can better troubleshoot with you then us via a forum.
What do you have for your 'mac auth profile' ?
Are you able to try for a giggle a user derivation rule based on the mac instead of the mac-auth?
http://www.arubanetworks.com/techdocs/ArubaOS_6_4_1_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Firewall_Roles/User_Role_Assignments.htm%3FTocPath%3DRoles%20and%20Policies|_____3
ACCP, ACCX #817, ACMP, ACMX #294
Contacted the vendor about it, and they've opened a support case. The
vendor's stumped, too; wish it worked but somewhat relieved that they
couldn't figure it out. Don't feel like as big of a dummy if they company
that does this kind of thing for a living couldn't figure it out, either
The senior engineers are supposedly looking into it; vendor rep suspects a
code revision on the controller might be needed due to the age of the
printers...
This message has been scanned for malware by Websense. www.websense.com
