Wireless Water Cooler
AP-135 bond
Hello
Is it possible to bond the interfaces on an AP-135 for ethernet redundancy, or to achieve over 1Gbps throughput?
So far it appears not, but I am looking for confirmation.
Thanks!
Re: AP-135 bond
Honestly, the AP135 cannot negotiate WLAN rates to push more than a gig of WLAN traffic.
Re: AP-135 bond
Thanks for the response! looks to me like it would top out at 900Mbps. Do
you happen to know if network (not just power) redundancy is possible?
Re: AP-135 bond
If the AP135 is plugged into 2 poe switches, it will take power from one. If the link on that interface goes down, the whole access point reboots and could be powered by the second switch.  That would be like a two to three minute outage.  Very few deploy in this manner.
