Wireless Water Cooler
Air Monitor
On a 3400 controller, how do you change an AP-105 to Air Monitor?
Re: Air Monitor
That option is in the radio profile
Make sure you create a separate AP GROUP for the AM
Thank you
Victor Fabian
Lead Mobility Architect @WEI
