Wireless Water Cooler
Occasional Contributor I
Aruba AP 175 access points
In refernce to the Aruba Ap 175 access point is an antenna required on both R0 R1 and R2 and also R1 R1 and R2? Can an antenna just be on R0 R1 and one on R1 R1?
Re: Aruba AP 175 access points
Whether it is r0 or r1, both terminals on each radio need to be hooked up to an antenna or have a weatherproof cap over them.
If you are only serving clients or doing mesh on the 5ghz radio for example, an antenna needs to be hooked up to both terminals on R0 and weatherproof caps on both terminals of R1:
According to the AP175 installation Guide:  http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=8939
Colin Joseph
Aruba Customer Engineering
