Wireless Water Cooler
Aruba Wireless Marketing?
Not sure which forum to place this in. I was looking for some Aruba Wireless Marketing slides or information. I need it to do a presentation. I found some things here in airheads, but I am not finding anything on HPE or Aruba site besides specific marketing for controllers or APs. Any help is appreciated.
Re: Aruba Wireless Marketing?
I think you would have to be a partner to obtain that:  http://www.arubanetworks.com/aruba-partner-center-has-moved/
Colin Joseph
Aruba Customer Engineering
and/or reach out to your local Aruba SE.
