Wireless Water Cooler
Best Wireless Card or Dongle Dual-Radio?
I am looking to purchase a dongle or wireless card (preferrably USB dongle) for my laptop.
I am not sure which offers the best price performance.
I obviously need something that is dual-radio 2.4 and 5
802.11ac is a bonus but not sure if these dongles are mature enough...
What do you recommend?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: Best Wireless Card or Dongle Dual-Radio?
I bought the following a couple of months ago and its been pretty good :
http://support.linksys.com/en-us/support/adapters/AE3000
I haven't had any good experience with the 11ac USBs ( Netgear , Linksys , Asus) but I read in a couple forums that some of those issues have been addressed with newer firmware
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Seems like a good product, I can find one for $55, worth it to try it out.
Thanks Victor
ACDX #420 | ACCA
Do you guys know any wireless dongle dual radio in which the manufacters actually care about firmware upgrades?
I got a AE3000 but linksys does not care about the firmware upgrades... for example i put it on a windows 8 machine and yes i got it to work but as there is no drivers for windows 8 the max speed i get its 54mbps... when the dongle is capable of 450 in a band...
Cheers
Carlos
Alternetworks Corp
