Wireless Water Cooler
Occasional Contributor I
External antenna gain on AP-214's
What values should I enter for the 5 and 2.4 Ghz fields?
Re: External antenna gain on AP-214's
They require external antennas.  Those external antennas would have the gain information on the packaging.
