Wireless Water Cooler
MVP
Full duplex wi-fi?!
source: http://timesofindia.indiatimes.com/tech/computing/New-technology-for-Wi-Fi-network-developed/articleshow/46584780.cms
Anyone else excited?
Okok, probably lots of years before we'll see an actual implementation if it ever comes to that but oh boy.. can you say byebye wires?
Koen (ACMX #351 | ACDX #547 | ACCP)
Trusted Contributor I
Re: Full duplex wi-fi?!
I first heard about this at the WLAN Pros conference as it's supposed to be part of the 11ax spec.  Very excited about the possibilities!
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
i had seen this mentioned some time ago but havent heard anything since - but it is a very interesting development.
http://sing.stanford.edu/fullduplex/
