Wireless Water Cooler
Frequent Contributor II
He uses wifi..
Birds are starting to use wireless technology!!
He uses WIFI
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
