Wireless Water Cooler
How do I disable ssh on an aruba 620 controiller
We have noticed that our Aruba's external port that connects it to the WWW is seeing SSH traffic from China and the Korea. Since we never remote into the device. We would like to shut that down.
If that is not possible we could like to see about limiting the attempts to connect to it befoe it refuses to respond to attempt to hack in to it. So if someone tried 3 times then the account would be locked for 30 minutes before the account could be used to try and get in again.
I would appreciate any help or suggestions on how to achieve this
Re: How do I disable ssh on an aruba 620 controiller
You would probably want to put a port ACL on it:   The ACL below only allows the uplink of the controller (fastethernet 1/0) to get DHCP from the provider.  Outbound traffic is allowed, but no inbound traffic besides DHCP is allowed.
ip access-list session dhcp-only
any any svc-dhcp permit
any any any deny
interface fastethernet 1/0 ip access-group dhcp-only session
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks.
But I need to have normal AP traffic cross the WWW port, but just want to block inbound SSH traffic
Russell Oliver
Network Engineer
Arizona Tile LLC
8829 S Priest Drive, Tempe, Arizona 85284
Phone
E-mail roliver@arizonatile.com
http://www.arizonatile.com
any any svc-ssh deny
any any any permit
