Wireless Water Cooler
Occasional Contributor I
How to easily remove an AP 135 from it's mounting bracket?
Does anyone know of a tool or trick to easily remove an AP 135 from a ceiling mount bracket?  We are looking to remove a number of AP 135's and replace them with 225's and would like to reuse the existing brackets.  There doesn't seem to be an easy way to remove them that we can tell.
Re: How to easily remove an AP 135 from it's mounting bracket?
Unless you have 4 arms, I've found it best to do it with 2 people, both armed with flathead screw drivers. Copious amounts of swearing is also required.
Brute force.
+1 For brute force. I still haven't broken one and I twist pretty hard.
Tim Cappalli | Aruba Security
...I broke a few. :$
Thanks Tim !
