Wireless Water Cooler
Mounts for ceiling tiles that extend below the rails.
I'm wondering if the ceiling mounts that come with the AP-325 work with ceiling tiles that extend below the rails.  We have some that sit flat on the rails, and other ceilings where the tiles extend maybe 1/4inch below the rails.  The included mount looks like it would push up the ceiling tiles that extend below the rails.  Is there a solution other than to cut holes in the tiles where the AP would push it up?
MVP
Re: Mounts for ceiling tiles that extend below the rails.
You probably need the AP-220-MNT-C2 mount kit for recessed ceiling tiles mount:
The AP-220-MNT-C2 ceiling rail adapter kit includes the following items:
- Adapter for Open (Silhouette) ceiling tile rails. The wider of the two adapters.
- Adapter for Flanged (Interlude) ceiling tile rails. The narrower of the two adapters.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_ViewDetails/Default.aspx?EntryId=11535
Please check with your partner or HPE Aruba SE if you need advise.
Herman
If you have urgent issues, please contact your Aruba partner or Aruba TAC.
Maybe it has two applications and it would work, but it looks to me like that's a completely different ceiling system than we've got.  The rails are the correct size for the adaptor that comes with the AP's to fit onto.  The tiles just extend below the level of the rails.  I've now got an AP-325 in hand and can show a picture of what I feared with the mount that's included.  It pushes up the tiles so they're flush with the rails.  The only way to use this mount and not have that happen would be to have to cut a rectangular hole in two adjacent ceiling tiles to make room for the ceiling mount without touching the tiles.
I like to avoid cutting tiles whenever possible because the ceilings will last for decades and the AP's are going to be replaced every 4-7 years, and each new model is a different shape using a different mounting scheme
From the documents on aruba's website, I don't think the AP-220-MNT-C2 is going to mount to this ceiling grid.  Do you think I'm wrong?
 Adam,
Did you ever find a solution for this?
I've got an Aruba TAC case in for this exact issue, and am waiting to hear back from them.
What I'm looking for is 115/135/205/215/225/325 equivalent to the AP-105-MNT-C - which specifically says it can do 15/16" recessed ceiling grid.
AP-220-MNT-C2 doesn't appear that it would work on 15/16" ceiling grid, looking at it's data sheet.
I could be wrong though.
Isn't AP-220-MNT-C1 going to be the equivalent part for AP-105-MNT-C which I think is what an AP-325 ships with.That pushes up the ceiling tiles where the rails are recesed lower than the surface of the ceiling tile. (see my picture in an earlier post)
My best idea at the moment is to use a clip something like this: http://s2.img-b.com/lightingdirect.com/imagebase/resized/330x320/progresslightingimages/progress-lighting-p8771-30-100.jpg and see if I can attach it to a AP-220-MNT-W2W and add an extra nut to the screw to make the wall mount bracket lower than the surface of the ceiling tile.  I need to get a AP-220-MNT-W2W ordered so I can try that to see if it works out like I think it will.
This is a very old thread, but the solution we used was the standard T clip, and cut a little notch in the edge of the tile on each side of the clip so that they drop down next to the clip, rather than being held up by the edge of the clip.
The standard clip is thick enough so that the top of the AP is below the tiles even after they drop into place.
That's maybe better than what I did.  I was just hoping to not have to cut the tiles.  I had metal clips that clip onto the ceiling grid, each has a threaded screw attached to it that a nut can screw onto.  So I used those to attach a wall mount bracket for the AP onto the ceiling, and put an extra nut on the screw to make it hang below the level of the tiles.  It's now much thicker than it otherwise would be but it doesn't push the tiles up.
