Wireless Water Cooler
Picture of spr-wl2-mnt, I can't find information on this
We have purchased spr-wl2-mnt for our S1500-24P switches and I need to know if we can rack these switches to a wall vertically using this or just the regular brackets that come with the switches.
Anyone have information on this part # spr-wl2-mnt
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Aruba
Re: Picture of spr-wl2-mnt, I can't find information on this
The rack kit that comes with the switch can be used for wall mounting. Check out the "Aruba S1500 and S2500 Mounting Kit".
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=11522
Thank you!
ACDX #420 | ACCA
