Wireless Water Cooler
last person joined: 11 days ago
Hang out and socialize with other community members in this off topic forum. Everything from industry trends to hobbies and interests are welcomed!
Question regarding 277's
  • 1.  Question regarding 277's
    Posted Sep 02, 2015 09:38 AM
    Deploying 277's.  We have them provisioned.  They are not coming out of "inactive".  Any thoughts?
  • 2.  RE: Question regarding 277's
    Posted Sep 02, 2015 09:39 AM
    How are they powered?  It needs to be a POE+ injector, OR a switch providing POE+ that has LLDP enabled on that port so it can communicate the higher power.
  • 3.  RE: Question regarding 277's
    Posted Sep 07, 2015 12:18 AM
    also check that the regulatory domain is updated,
    show ap allowed-channels country-code XX ap-type 277
    where XX is the country code that the ap regulatory domain profile is using. if you see no channels listed, then you should download the latest DRT file from the support site. If you see channels, very likely you should focus on POE/LLDP issues as per Colin's post
    regards
    -jeff
