Wireless Water Cooler
Report of all WAPs connected at 100 Mbp
Can someone help me -
I am trying to run a report in airwave to display the Input Capacity of all the WAPs?
(To identify all APs connected at 100M)
I can see the information under APs/Devices->Monitor
Wired Interfaces
Interface Name MAC Address Clients Admin Status Operational Status Type Duplex Aruba Port Mode Input Capacity Descending Output Capacity
Enet018:64:72:C8:9F:420UpUpgigabitEthernetFullN/A100 Mbps100 Mbps
Enet118:64:72:C8:9F:430UpDowngigabitEthernetAutoTunnel--
I just can't find the right variable in the report and I don't know psql well enough to find it via command line.
Phil
Frequent Contributor I
Re: Report of all WAPs connected at 100 Mbp
I've asked a similar question before and have placed a feature request on the "ideas" site. I've not looked in version 8 to see if they've added this.
I found the following commands that might be helpful. This is the first I've looked at this and don't have any idea where the info for speed is stored..
Put the databas schema into a file named amp_schema
pg_dump -Uairwave airwave --schema-only > amp_schema
Export all fields from the table ap to a csv file. I don't know if what is needed is in this table or not.
dbcsv "select * from ap" > aps.csv
I'm not sure if what I'm looking at is right, but this might provide what you need.
dbcsv "select ap.name,interface.if_speed_in,interface.oper_status from ap INNER JOIN interface ON ap.id=ap_id WHERE interface.oper_status=1"
This shows the type field:
dbcsv "select ap.name,ap.type,interface.if_speed_in,interface.oper_status from ap INNER JOIN interface ON ap.id=ap_id WHERE interface.oper_status=1" > intspeeds.csv
Type ID and AP Type
270, rap2
296, 105
369, 175
415, rap3
464, 225
Again, I'm making this up as I go, but it looks sane.
Works like a champ - thanks much!!!
You are welcome. This thread helped me too. There are several APs running at 100 Mb that should be at 1 Gb. It also points out where we still have old 100 Mb switches.
Here is an updated version of the script that might be a bit more useful. It puts the ap info into a file, sends the file as an attachment, and then deletes the file. Someone that writes shell scripts can probably clean it up a bit.
dbcsv "SELECT ap.name,interface.if_speed_in/1000000 AS connection_speed FROM ap INNER JOIN interface ON ap.id=ap_id WHERE interface.oper_status=1 AND (ap.type=296 OR ap.type=369 OR ap.type=464) ORDER BY connection_speed,ap.name" > ./intspeeds.csv
echo "Access Point Port Speeds" | mail -s "Port Speeds" -a intspeeds.csv userid@somecompany.com
rm ./intspeeds.csv
Where do I run this script? Launch a ssh or telnet window to the Airwave server? Or can this also be ran in the GUI?
I'm not sure if this is available in the current version of the GUI. The script I used was via ssh and the CLI on a previous version. The current version of Airwave restricts shell access. I'm not sure if there is a way to access the database with these restrictions. I tried running the script on the current version when TAC had opened a shell and it didn't work and I didn't have time to debug it. Good luck.
