Wireless Water Cooler
Usning poirt ojn Aruba 620 to mnitor traffic across other ports
Is it possible to configure a port on the Aruba 620 Controller to act as a monitoring port much like you might with a HP or cisco switch.We would like to tap the traffic from the internal AP's and see what user is doing what when out downstream monitoring tool indicates that an Aruba based wireless client is infected with a virus.
As we are configured today, we monitor the traffic on the www side of the Aruba and can see that the NGFW indicates there is a problem, we just do not have an easy means of determining who or what is causing the problem.
Any suggestions of help would be great.
Re: Usning poirt ojn Aruba 620 to mnitor traffic across other ports
port monitor
http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/interface_fastethernet__.htm
