A few months ago and for my first time I deployed several iAP225s in a cluster configuration managed by the Virtual Controller. I was using vlan 100 for management and vlan 101 with SSID ABC for client dhcp/data. Everything else is strictly default. All appeared to work ok
I have since added a few more iAP225s but in another building entirely. These are configured under the previous cluster and VC and using vlan 100 for management but this time vlan 102 for client dhcp/data.
The reason for the two separate client vlans in each building is they already existed and I simply wanted to use what was already there.
Some other wifi vendor APs allows multiple instances of the same network SSID with separate vlans. Your's appears not to but I was told that vlan pooling might be the answer.
I therefore reconfigured my existing ABC SSID to include both vlans 101 and 102. So far so good.
Since I only need client vlan 101 in the first building I do not pipe vlan 102 there and since I only need client vlan 102 in the second building I do not pipe vlan 101 to it. All this eventhough my ABC SSID is configured for both.
I have since noticed issues with clients getting dhcp/IPs. Even in the initial deployment area.
Are there other configurations needed to use Vlan Pooling?
Do I have to pipe all vlans configured under Vlan Pooling to all iAP225s in the cluster?
Would the client devices be trying to connect to the first vlan listed in the Vlan Pooling list?
What is the "best practice" when using Vlan Pooling?
Thanks in advnce for the help.
Claude.
