Wireless Water Cooler
WLC na APs
hi all
my Aruba AP 93 is not going to ragister with my Arubs 620 WLC
pleas help me how to ragister this APs
Re: WLC na APs
Are the AP93s in the same VLAN as the 620?
What version of ArubaOS is the 620 running?
Are you supplying DHCP to the AP93s?
Re: WLC na APs
respected sir.
yes APs are in the same VLAN
the version of aruba os 620 is [image: Inline image 1] 6.0.1.0
ye i have configure DHCP to the APs
Re: WLC na APs
The minimum versions of ArubaOS code required for those access points is 6.0.2.1, 6.1.2.0 according to the datasheet http://www.arubanetworks.com/pdf/products/DS_AP92-93.pdf
