Wireless Water Cooler
What causes a configuration mismatch on a 650 controller
In Airwave I am seeing a configuration on a 650 controller.  Could this be an issue with the controller firmware version being out dated?
Frequent Contributor I
Re: What causes a configuration mismatch on a 650 controller
Mismatch means that the configuration at the controller and Airwave differs.
HTH,
Marek
Marek Krauze, CWNE# 174, ACMX #295, ACDX #356
Something cool, helpful or interesting in my post - click the Kudos Star.
Helped to solve your problem - Click Accept as Solution
Aruba
If you are using AirWave in monitoring only mode and not intersted in configuration/mismatches, you can disable auditing on the group the device is a member of.  This will remove any mismatch messages.
AMFX | ACCX | ACDX | ACMX
