Wireless Water Cooler
What is flag 2 - Using IKE version 2
A little background. I am trying to add APs in the controller before they are installed.
I added them via whitelist-db cpsec add.
Enabled Control plane security in the controller, the AP came up with the name and I had set, and in the group I had predefined.
But its coming up with flag 2 - 2 = Using IKE version 2.
What exactly does that mean.
TIA,
Erga
Re: What is flag 2 - Using IKE version 2
ALL CPSEC APs use IKE version 2.  It is an informational flag.
Thank you
