Wireless Water Cooler
XBOX on campus with NAT Moderate
Those of us in the EDU know about the persistance of the students with XBOXes in the dorms.
My students are getting moderate NAT so after some research i tried a test and shut off the IPS on my Cisco ASA 5525 IPS. the problem is not at that level. So this backs me into the 7210 or the AP 205's  Anyone with experiece on these have any thoughts.
Thanks.
Chris S.
Regular Contributor I
Re: XBOX on campus with NAT Moderate
I use a Palo Alto Firewall. Reading through their documentation it points to the issue being upnp traffic. They do not have a solid fix outside of 1-to-1 NAT to the Console.  This specifically applies to 'strict NAT'.
https://live.paloaltonetworks.com/docs/DOC-3695
