Wireless Water Cooler
clients complaining of slow network
I have clients complaining about slow wireless network. they mostly come from a single floor that has about 30 users on it. they have 3 AP's about 25 feet apart about. there is 1x135 and 2x225's all clients are MAC's either MAC Air or Pro. 2/3 of the clients seem to prefer the 135 for some reason. the AP's are connected to Gig ports on the switch and PoE+ for the 225's. Most clients are doing web requests and the others are doing go to meeting.
Any idea's on where and what to start troubleshooting?
Re: clients complaining of slow network
What band are the clients connected on?
Do you have 'drop broadcast/multicast' enabled?
Is the slowness at particular times of the day?
Do you have client-match enabled?
ACCP, ACCX #817, ACMP, ACMX #294
Super Contributor I
What's your min and max power settings on your arm profile? High power levels can cause roaming issues.
ACDX #419 | ACMP |
What band are the clients connected on? 5.0GHz
Do you have 'drop broadcast/multicast' enabled? i"m not sure
Is the slowness at particular times of the day? not really, random days and times, but consistan complaints
Do you have client-match enabled? no, i dint believe it is on by default and i dont thing the customer configured it.
Not sure i will look today as soon as i get access to the controller. i'm sure it is default settings.
