Wireless Water Cooler
iAP225 Virtual controller GUI interface sleep mode.
Hello all,
I am currently using the GUI interface of my iAP225 Virtual Controller. I typically like to have it displayed on my screen so that I can at a glance see what's going on my wireless network while doing something else.
However, if I don't click on anything on the VC GUI interface for a small duration of time it goes in sleep mode. I must then re-enter my VC username and password to have the info displayed on my screen once again.
Is there a way to increase the amount of time before the VC GUI interface goes in sleep mode?
