Wireless Water Cooler
Occasional Contributor I
is the 7030 controller app interface similar to other models?
Is the controller application interface on the 7030 the same or similar to the 3000 or 7200 series?
Aruba
Re: is the 7030 controller app interface similar to other models?
The WebUI is consistent across all controller models.   The only difference would be in code specific additions (but consistent on all controllers).
AMFX | ACCX | ACDX | ACMX
