Wireless Water Cooler
snmpwalk is not picking up the aruba *.my mibs even when specified in the snmpwalk command
trying to have nagios ask the controller for specific information on the AP's deployed in the enterprise. these people do not have access to airwave so an opensource solution was specified. tried changing to .txt and .mib still doesn't like the command. are the .my files only for airwave and/or is there a .mib file available?
Re: snmpwalk is not picking up the aruba *.my mibs even when specified in the snmpwalk command
How are you specifying them on the command line? You'll need both -M and -m.
Norman
Hi Norman,
Been trying a few different ones and didn't have much success. Seems when I
do only the OID # I get what I want. Maybe that's just the way to do it?
Have to admit I didn't do both until you suggested.
[root@rhmonitor01 mibs]# snmpwalk 10.3.77.103 -v2c -c generous -m all -M
./usr/share/snmp/mibs/aruba-wlan.my wlsxWlanAPTable
No log handling enabled - turning on stderr logging
wlsxWlanAPTable: Unknown Object Identifier (Sub-id not found: (top) ->
wlsxWlanAPTable)
