Wireless Water Cooler
version
hi all
pleas guid me how can i make my user id at aruba
Super Contributor I
Re: version
If you have a SSO sign in (like what you use to sign in to airheads) then you should be able to use that for any other Aruba system you have access to (except licensing)
ACDX #419 | ACMP |
Re: version
i need to upgrad my ios version 6.0.2.0 how can i get thet version and what
is the procedure of updating my ios aruba WLC620 my AP is 93
Super Contributor I
Re: version
Support.arubanetworks.com is the site you'll grab any firmware from. You'll need a valid support contract to access it. To upgrade login to the GUI on your controller and go to Maintenance - Image Management - Choose local file - navigate to it on your computer - choose your opposite partition and upgrade.
ACDX #419 | ACMP |
