AP local DHCP address
We have remote access points located at many sites, they are working fine. However the problem we have is that 2 APs got installed without anyone making a note of their location.
I am trying to get the local IP address given by the local DHCP server on that site, this way I can see it is plugged in to subnet 192.168.xxx.xxx this then telling which site it is plugged in to.
Anybody know how to do this, I can't see this option anywhere...
Local DHCP Server Address Obtained
Use "show datapath session ap-name ". There will be two entries that are private addresses over UDP 4500 to the public address of the controller. That is the private address of the AP:
(m3.arubanetworks.com) #  show datapath session ap-name hroberts-rap5
Datapath Session Table Statistics
Current Entries 11
High Water Mark 25
Maximum Entries 4095
Total Entries 4362
Allocation Failures 0
Duplicate Entries 0
Cross linked Entries 0
No Reverse Entries 0
Max link length 2
Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Flags
00:0B:86:66:11:4F 0806 0 0 0 1 local 4b F
10.69.18.207 224.0.1.116 2 2 2 0 0 0 0 dev7 c078 FC
10.69.17.255 10.69.17.233 17 137 60028 0 0 0 0 dev7 3a FY
10.69.17.233 10.69.17.255 17 60028 137 0 0 0 1 dev7 3a FYC
213.31.249.247 192.168.1.246 17 4500 4500 0 0 0 0 local d7a0 F <----------
192.168.1.10 224.0.0.1 17 56400 8611 0 0 0 0 dev4 16 FDYC
10.69.17.255 10.69.17.233 17 137 49350 0 0 0 1 dev7 38 FY
192.168.1.246 213.31.249.247 17 4500 4500 0 0 0 0 local d7a0 FC <----------
10.69.17.255 10.69.17.235 17 137 137 0 0 0 0 dev7 18 FY
10.69.17.233 10.69.17.255 17 49350 137 0 0 0 1 dev7 38 FYC
10.69.17.235 10.69.17.255 17 137 137 0 0 0 0 dev7 18 FC
In the example the ip address of the AP is 192.168.1.246.
Colin Joseph
Aruba Customer Engineering
Re: AP local DHCP address
Thanks very much, worked perfectly. :D
