Wireless and RF
Frequent Contributor I
AP125 11n ftp rates difference
Hi there,
Can I check with you what is the root cause of the differences in data rates when we do 'put' and 'get' in ftp?
Cheers,
Michael
Re: AP125 11n ftp rates difference
Before I post an answer from someone WAY smarter than I, should I assume you are seeing faster 'puts' than 'gets'?
Jerrod Howard
